Discuss Powercleanse Radhammer..... How much??? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Couldn't justify £30-£40 for something so simple........ So araldite+cut down sds bit +spare nylon hammer head=pennies ☺️
Won't last as snapped a few adey hammers
Reply to Powercleanse Radhammer..... How much??? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All This is following on from thread I made a few days ago but can't seem to find I'm in a bit of a bind with my CH design where I want to sort all of my rads and do some other bits including fitting a filter but I'm stumped on how to drain down due to how the system is put together...
Seems to be some flaws in the brass of this tap (faucet?). It has fine scribbly black lines crossing from the inner of the pipe to the outside. I guess that's why it still drips a bit even after a number of reseating attempts and many new different washers. Is this something others have seen...
Hi All, I hope you are doing well. I have this 3.25mm lead-free grade 99c solder wire. I know that the good practice to bend the wire before soldering so you know exactly how much it is absorbed by the flux. I know too little isn't good and too much is as bad. I need to connect two 15mm pipes...
Hello! I was checking something in the toilet cistern. I flushed, but holding the float ball, so the cistern wouldn't be filled. With a very low level of water in the cistern, I flushed a couple of times. Then I let go of the float ball and the cistern was filled. I didn't do or change...
My plumber fitted a shower, 2 of the walls are glass panels and one is a tile board (wedi board). He joint the wedi board pieces (3 pieces) close to each other but didn't use any joint sealant. When I asked him whether this will be an issue for future leaks he dismissed it. How worried should I...
