Discuss Potterton 100e problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
steveroy
Hi
I have recently moved into a bungalow that has a Potterton 100e bolier in the roof. There are a few issues that i could do with some advice on.
1. When i turn on the hot water tap, it shoots out under pressuer but takes maybe a minute to become hot. this wastes a huge amount of water.
2. The boiler shuts itself down. I got home last night and the red light was on but the boiler was still making a noise like the extract fan was running. when i pressed the reset the boiler came back on and is ok again.
3. During christmas the boiler made some dreadful noise like a artic lorry was parking in our back garden. It was quite scary. This was followed by a noise that sounded like a rush of air being expelled. When this happens the boiler shuts down. It does not seem to happen when the boiler is running.
Any ideas please, i dont want to call anyone out as it rund most of the time and could be difficult for anyoen to diagnose.
1. It's a combi boiler so it does take time for hot water to get to the taps.
2 & 3 Have you checked the system pressure gauge underneath the boiler? The needle should be above 1 bar. It sounds that there isn't enough water in the boiler so it shuts down too early and makes a noise. There should be a silver flexible pipe with a tap connected to it for putting more water into the system. Open this tap slowly and watch the needle go to around 1.5 bar.
Thanks Wales84
I will give this a try, it shut down again yeaterday while it was on this time. thats twice this weekend. What a pain.
I will let you know if this solves it.
Hi Wales 84
You were right about the pressure being too low, i had recently bled one of the rads as i thought this was the problem and didnt realise this would have an effect as well. Clearly it didnt help with the system pressure.
It was less than 1 bar, i did turn the wrong knob and the pressure dropped further (not very bright), however as you pointed out the silver pipe with the tap brought the pressure back up the 1.5 bar.
I hope this solves it now.
Thank you for your help, clealry this has saved me paying for a call out.
Steve
Reply to Potterton 100e problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new well maintained Worcester combi boiler. We weren’t convinced the heating was working right and then got hit with a £610 energy bill for the first 6...
MartinPod81
M
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise coming from my copper water pipes when no water is being used? It basically sounds like the noise you hear after the water shuts off when your toilet bowl...
Hi all, Got a strange grating noise when the mains water is running in a property I'm looking after. It's a ground floor flat, with a first floor flat above it, and both share the same mains water pipe, and I believe the stopcock behind the washing machine isolates all water to both properties...
Hi All! I hope you can give me some advise. I had combi boiler (Viessman vitodens 100-w 30kW) installed about half year ago. Recently I start hearing one single bang when hot water is opened at any of taps around house. It sound like someone in other room will knock a radiator (not relly loud...
3K
Hello, I'd love some advice on my system, I've had a couple of plumbers come in that seemed to specialise in gas systems and seemed perplexed by my all-electric systems and the issues I'm having. My system is all electric heating and hot water system, in a flat on the 4th floor. The mains...
