Discuss Plug waste pipe hole - kitchen sink in the Plumbing Forum area at UKPlumbersForums.co.uk.
  1. michael12345
    michael12345 New Member
    Hi - looking for something suitable to simply cover the hole for the sink overflow. I don't need it connected up to the waste so just want to use somehing to fill it and make it look nicer.
    Could anyone recommend something? The hole is approx 30mm wide.
    Many Thanks
  2. townfanjon
    You can buy a cheap overflow kit , you get everything you dont want lol , but they come with the plastic/chrome bit you need
    • Like Like x 1
  3. ShaunCorbs
    Electrical blind grommet??
  4. snowhead
    snowhead Well-Known Member
  5. Stigster
    Stigster Plumber
  6. michael12345
    Thank you for all the great suggestions!
    Sorry if it's a stupid question but based on the picture posted, if I was to get some sort of stopper, would I need access from behind the sink in order to successfully be able to screw the item on?
    Many Thanks
  7. Stigster
    Stigster Plumber
    You would need to get one hand in behind the sink to do the nut up on the back of the blanking plug. Usually this is just about accessible because an overflow and overflow pipe would normally be fitted there. Failing that, you could silicone the blanking plug in with some silicone/sealant just from the front. As it will not be required to hold pressure this should suffice if access is impossible.
  8. michael12345
    Ok fantastic, thank you very much! Will try that! :)
  9. hammers4spanner
    hammers4spanner Plumber GSR
    Any waste pope through a joist should be banned imho void house insurance . Get so fed up with this low level tray nonsense from customers its getting daft now.
Loading...
Similar Threads - Plug waste pipe Forum Date
No plug on boss connection = leak & smells Plumbing Forum Feb 18, 2019
Radiator blanking plug size Central Heating Forum Jan 27, 2019
  1. kitchen sink waste sizes
  2. what size waste pipe for kitchen sink
  3. plumbing a plug andpupe together advice
