Discuss please help! over 3 months without shower! in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. annawoolgar
    annawoolgar New Member
    hi,
    on 1st May we started our bathroom refit - including fitting a new shower cubicle with a smartap shower instead of a bath and electric shower, we were advised by our plumber to buy a positive head pump (ct60b), however, this did not appear to work, so we had to purchase a negative head pump (esp50cpv), as advised by smartap, we have tried everything to get the shower working properly, including moving the evalve into airing cupboard. Our shower will still not work - the evalve says it is not getting the 1 bar required to operate, my plumber says he cannot see a problem, but there obviously is one as the shower only trickles, its been so frustrating and i am not sure what to do now, I tried to return the shower about a month ago, with the mind to just install another electric one, but smartap would not authorise a refund due to it not being their fault. please advise,
  2. ShaunCorbs
    Any chance of a few pics of the pump etc ?
  3. rpm
    rpm Trusted Plumber Top Contributor!!
    Bathroom cold tap is plumbed in wrong on your drawing. Nice drawing by the way.:)
    • Agree Agree x 1
  4. sammathias
    sammathias Plumber GSR
    The pump isn't kicking in?
  5. Tim S
    Tim S Member
    Hi..some photo's of the install would help...is there a reason why the pump couldn't be installed at the base of the hot water cylinder ?(which would have saved you the cost of a universal/negative head pump).
    Have you tried bypassing the processor in the loft?.
    Why did Smartap say it was NOT their fault..did they send an authorised engineer?
    If we could see the install the problem might be obvious!
  6. annawoolgar
    How is cold tap plumbed in wrong? It comes out of cold tank in loft and then splits into taps and pump. Thanks for your reply xx
  7. annawoolgar
    I can get photos later, I don’t know why plumber didn’t put pump at base of hot tank, he put it halfway down, I have bypassed the evalve to check water pressure but obviously have no control over temperature. Thanks for replying xx
  8. bogrodder
    bogrodder Plumber GSR Top Contributor!!
    Could either be that
    A) airlocked, could be in a few places
    B) filters blocked on loft unit or pump
    C) piped up incorrectly
    Take your pick
  9. annawoolgar
    Some photos of pump - please excuse the messy pipe work - it’s been swapped about so many times, it will be tidied once all working xx
  10. Meady
    Meady Plumber GSR
    Judging by that install it’s no wonder he can’t figure it out :eek::eek::eek:
    • Funny Funny x 2
  11. ShaunCorbs
    thats bad
    • Agree Agree x 2
  12. bogrodder
    That’s never a professional install
    • Agree Agree x 1
  13. annawoolgar
    It was installed by a plumber but we used existing pipe work when trying different things out, so I am to blame for that, the smartap tech had me change the pump, and try the shower evalve in the airing cupboard too, the plumber has been round but said he would sort it all out when problem is sorted xx
    I am wondering if the problem could be because the flow from cold tank is split, so therefore has less pressure, a couple of times the pump has got too hot so that would make sense too - so if that is the case how can I fix it?
    Can I run a new pipe from tank? Or do I feed shower directly from mains but then can I use same pump due to not running cold through? Am I able to block it off or do I need to buy a single impeller pump? I need to be able to test a solution first before I throw more money at my plumber xx
  14. Meady
    Meady Plumber GSR
    Where does the hot pipe from the pipe connect onto? And yes a dedicated cold feed would help.
    • Agree Agree x 1
  15. annawoolgar
    From the top of the hot water tank one pipe feeds the pump/shower and the metal pipe that goes across to the corner feeds the taps xx
Loading...
Similar Threads - please help months Forum Date
Hello all - please help - dishwasher inlet into sink tap New Member Introductions Feb 10, 2019
Please help - have i been ripped off? Plumbing Forum Jan 13, 2019
