Discuss Please explain......... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
bogsdollox
pardon my ignorance but what is the difference between Polybutylene barrier pipe and PE-X barrier pipe please and which is the best to use.
I am wanting to turn my bath around and it was suggested by a friend that I used plastic pipe instead of copper under the floorboards. Also, if i turn the bath around obviously it means that the bath waste will be at the opposite end to the outlet. what is the best way to run the length of pipe back down to the outlet.
The barrier pipe has got a barrier between two layers to prevent the ingress of oxygen. Designed for central heating use.
Waste run depends on location but the easiest is above the floor between the legs of the bath and using a 42mm hepVO valve and knuckle adaptor.
Mike
Ok Mike, thank you. Both types of pipe are barrier, just wanted to know the difference between PE-X and Polybutylene.
Polybutylene is a polymer (plastic) based on butylene gas, which has 4 carbon atoms in each molecule, whereas PEX (crosslinked polyethylene) is based on ethylene gas, having 2 carbon atoms per molecule -- if that's any help!
Polyethylene ('Polythene') was commonly used to make washing-up bowls etc., but the crosslinked PE-X has better properties for plumbing pipes (more resistance to cracking or crazing with time).
Its got to do with oxygen entrainment, at a microscopic level many plastics have holes, not big enough to let water out, but big enough to let oxygen in. The hole size varies from plastic to plastic.
The oxygen of course promotes corrosion so you don't want it in the system if you can help it.
So basically they try different mixtures to find out which combination gives the plastic the cost and properties they want for the intended application of it.
Reply to Please explain......... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Good afternoon, please see my attached diagrams One is the current layout And one is where I propose to add another boss to add a shower waste. This horizontal run is below floorboards but I can't get to the TEE or under the tee to add a boss vertically. ( the current Bath is bossed way in...
Hi. I'm having some issues with my boiler / central heating and have enlisted a local 'Combi Heating Specialist' to sort it out but he seems to be making things worse. I really need another expert's opinion, to put my mind at rest, or help me make the decision to stop using his services. I...
3K
Hello ! I have recently moved into a new house – or rather a 1960s built house. The central heating system looks to be around 10-12 years old Its conventional mains gas boiler central heating system (not a combi) the boiler is an “Ideal logic 18” – with hot water tank in an upstairs airing...
4K
Good morning, I recently had an extension, new bathroom and new en-suite fitted. Prior to the works the hot water worked. Now we have moved back we have no hot water. British gas came for 5 hours on saturday and replaced every single part of the boiler to do with the hot water as well as the...
3K
Hi there, please help dont have a clue how to set this up. Ive recently installed a complete new central heating system in my house myself. The system is up and running and works okay but I feel it could work alot better if it were setup properly. Im not a plumber and really understand how parts...
3K
