Discuss Plastic pipe on hot/cold to boiler? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
macka09
What’s the protocol if we find plastic pipe to boilers(within 100mm)? Found one with the hot and cold piped right into the boilers tails?
Loads like that mate, min of 1 meter away in my book , but should be more lol .
It’s a newish install aswell. Other than advising the customer what are we supposed to do? Cap it? AR it? All I get from colleagues is don’t worry about it, which is annoying.
Nothing to do with gas safe just note down and move on
Only bit I would be iffy is a blow off
That’s why it concerned me. I advised the customer that it wasn’t ideal like that and to have it replaced with copper.
Can’t force them all you can say is manufacturers don’t recommend it
Check with the boiler manufacturer. I'm told one or two have fancy controls fitted that would allow for plastic to be connected directly. Others will say 1m or 1.5m Get their advice.
I always pipe mine in copper, generally any pipe work on show but I think the regs and manufactures instructions only specify 1-2m on the heating circuit, due to the higher temperatures
Some manufacturers are as little as 600mm from boiler and it would be more specific to heating flow and return, don’t see hot and cold as an issue as it more relates to temperature
Reply to Plastic pipe on hot/cold to boiler? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
