Discuss Pipe threading set wanted in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Masood
Anyone got a set they want rid of? Don't mind what make - I've heard Ridgid are good, used Rothenberger at college, seemed OK.
Looked at REMS Amigo electric one but seems a lot of money for something I'd use very rarely.
Need to have 1/2", 3/4" and 1" dies as a minimum.
Cheers!
Keep your eyes on eBay I missed out on a full presto minor kit the other day with 3/8 through to 1 1/4 dies. Went for £35 in the end
If your only going to use them sparingly then get a cheap set like draper or similar. Does the job and if you break them it's no heartache
Cheers yeah I saw that one. It's silly money for second-hand kit.
Silly money no do you know how much they sell for new ? :D
I got a set of 6 ridgid second hand on eBay for £45. I've only used the 1/2" on one job but it did the trick.
Ah well. I've just bought a REMS Amigo machine with 1/2" - 1 1/4" off eBay for £300. Looks brand spanking new..
Thets good as a new one retails at 600 110 or 240 ?!
I tend to hire the Rems electric ones, they are a good bit of kit and when they go wrong we get them replaced in 24 hours. For how often they were needed it worked out more cost effective.
Try JMS for hire, if you don't have much luck in buying them, they cover London. 01582 467 000.
Cheers!
Managed to miss the post when you said you had got one! Glad it's sorted.
Reply to Pipe threading set wanted in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised valves simple bi-metal thermostat on wall in flat with 4 standard TRV's rarely used so not worried about the flat, and main house has Nest Gen 3 in the...
Hi all, Have got an old 60/70s PVC soil stack, the Toilet is going into a Hunter branded socket which has an old O-ring design (quite flat with 3 or 4 ribs on it). It's painted in a fetching pink/purple colour in the photo. Tried to revive it with some grease before inserting a short length of...
Hi I need some advice as this has been ongoing since august and nobody can find a problem but meantime water is damaging my walls. The lady upstairs had a plumber in July who relocated her washbasin shower and fitted a new radiator.He caused a bad leak and came to fix it in august and I thought...
Hi, After years of using a pumped electric shower (Triton t80 pumped), it's now dying and I'd like to replace it with a 'normal' mixer shower running off the vented hot water tank as this is now largely heated by solar PV . When we first moved to the house there was a shower head coming off the...
Hi, We are having PV panels fitted which will dump the excess energy into our hot water tank. Our house originally had a large 210L economy7 hot water tank (cold tank in loft), but the hot water tank died 18 years ago. At that time we fitted a smaller 117litre tank and went for fitting electric...
