Discuss Panicked tenant re. boiler asbestos in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Been there donkeys years so try to just forget about it, if not start looking for another house because I can’t imagine the Landlord is keen to spend a few bob.
Update - asbestos assessor thinks the sealants (I guess the mastic containing fibres mentioned by the manufacturer) and rope have been replaced but has taken samples for testing to make sure.
Reply to Panicked tenant re. boiler asbestos in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The council are offering to update the fire and inefficient old radiators and replace the old fashioned boiler with a new combi one. They want to move the boiler from the tank cupboard in the bedroom to the much bigger walk-in wardrobe, presumably for convenience as there seems to be a gas pipe...
Deleted member 120897
Hello I’m hoping for some perceptive / input as I’m a long-distance landlord trying to unpick the best thing to do. Gas safety certificate was done on my rental flat (1st floor) which has a 10 year old Aviston E-combi EVO boiler. It failed based on rusting external flu components, which has...
Hey there I'm looking for some advice on a potential issue I'm having with an old back boiler. So just moved into my parents' old house with my partner, it's a terrace with back to back chimneys in the kitchen and the sitting room. The fireplace in the kitchen is the old back boiler that hasn't...
Hi, i've got a job with a Vaillant Ecotec 630 system boiler, and i don't know the full history but the house has definitely been extended significantly since the boiler was installed. There's now 21 radiators/towel rails. It's getting to temperature, but even after balancing, it's not heating...
Context for issue: Last winter the temperature switch on my boiler shorted somehow, the boiler was then running WAY too hot and ended up blowing/melting a hole in one of the pipes. I repaired this by putting in a new stretch of pipe in and just connecting it to the existing pipes with two...
