Discuss Pan Connector problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, does anyone have any recommendations for what pan connector arrangement would be best suited for a side entry soil pipe with 3” vertical offset? The pan is an ideal Standard Della and the deep side of the pan slightly obscures the soil pipe by about 5mm. I tried a straight flexi but it fouls the wall and a 90deg flexi was better but it seems to want to pull off the pan spigot and doesn’t sit straight in the soil pipe. Many Thanks
If you use the second option I think you will need a Multikwik Multilink connector MKL1, it is just a sleeve that you put over the fins of the first connector before pushing into the other connector. I got one recently from Wolseley to do a job at my daughter's and it worked a treat.
Reply to Pan Connector problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
