Discuss New soil pipe dilemma in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Looking for a bit of advice on the best way to do things with a new soil pipe, apologies if its not complexity clear what im trying to do but i'll do my best to explain. The current layout is this:
I need to move the soil pipe to the side of the house for the new bathroom and for the new downstairs toilet. However to save cost I would like to reuse the existing sewer pipe. The issue is how best to connect the vertical soil pipe to the horizontal underground pipe, as i see it there are two options:
Or:
My concern is clogging where the vertical pipe meets the horizontal pipe from the downstairs toilet. What would people recommend?
The top one will be better keep away from the house to avoid the footings and any other services as above building control will need to pay you a visit . Cheers Kop
Reply to New soil pipe dilemma in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi , i'm new to this forum & would like some advice , i have an upstairs bathroom & was wondering if i could put a cloackroom loo downstairs , my worry is how do i connect to the existing soil pipe , or is it possible to dig under where the new loo will be in case the soil pipe runs along the...
Hi - I'm not an expert but wondered if anyone might be able to assist. I've replaced an old toilet with a new one. I've used the same water inlet pipe, and have just replaced the right angled soil pipe connecter (110 at toilet end to a 97-107 connector end to existing soil pipe). It's secured...
1K
Hi, I've not posted for a while, not a plumber, but a keen DIYer who likes to try and do things without bodging if I can. Basically I'm wanting to create a cloakroom toilet in our utility room, theres already hot and cold feed so thats one job made slightly easier, thankfully. The problem I'm...
Hi all, Have got an old 60/70s PVC soil stack, the Toilet is going into a Hunter branded socket which has an old O-ring design (quite flat with 3 or 4 ribs on it). It's painted in a fetching pink/purple colour in the photo. Tried to revive it with some grease before inserting a short length of...
I'm a DIYer and have a problematic toilet setup to fix: The waste pipe was installed too high for waste to flow out from a standard toilet spigot, so I want to install a wall-hung toilet on a frame to get some extra height. To put it where I want it though, I'll need to rotate the bottom...
