Discuss New Build Advice First Fix in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I wanted to ask you guys for some advice. How would you advise to run radiator pipes in new build flats? The floors are all concrete, someone advised to run them in the floor before the screed goes in?
Your advice and help is appreciated.
Hi & welcome.
I’d never advise anyone to lay pipes in concrete because if there are any issues how would you access the pipe.
You have 2 options
1. Surface mounted you run all the pipes along the walls and box them in.
2. Or you lay ducting in the concrete and run the pipes in that. Manthorpe Pipe and Cable Ducting 150mm x 70mm x 3m - Box of 10 | Drainage Superstore ®
However you should speak to the engineer that’s installing the heating system.
Run them in ducting under the screed. Do it in 10mm plastic have a manifold somewhere above ground then run in 1 continuous run to the rad so you have no joints under the floor.
Do they need to go in the floor could you do drops ?
Thanks for your replies. Ideally in the floor to make the job neat as possible. The ducting in the screed doesn’t sound like a bad option if it’s run around the perimeter of the rooms?
The walls are blocks but they are load bearing as there’s concrete floors.
Gas is going to run externally straight into the kitchens where the boilers will be.
So dot and dab plasterboard
If you go up and have drops you will have to have a false ceiling. The ceiling and adjoining walls will have to be fire rated so you cant have pipes sticking through everywhere.
This will have to be done anyway regardless of if there’s anything up there
The sites I've worked on haven't they just double boarded fire board on ceilings. No need for a false ceiling.
How did they fix it normally Battons to the ceiling
What the plasterboard? Either straight to the joists or yeah onto batons on the joists.
That doesn't get past the fact building control do not like pipes coming through causing holes into the fire protection. Not sure how electricians get round it but from past experiences your better off going down and up.
Won’t be a hole in the ceiling anywhere you can fire protect
Reply to New Build Advice First Fix in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, Looking for some advice please. Got a building, all one level with 7 radiators. 3 individual ones in separate rooms then 4 radiators all together in one large room. The issue is with the 4 radiators in the large room. Basically not getting hot, the first 10% of the radiator is...
Hi everyone, I've joined the forum today as I've found myself going round in circles with what I think might be a pretty simple problem, hoping someone can help. Our dishwasher is leaking and the manual says this can be fixed by cleaning the water inlet filter. To do this, we need to close the...
Hi could anyone give advice please ? I went to look at a new build for sale they are apartments/ one house on top of another all properties will be privately owned by individual buyers, a guy on-site pointed out that the plumbing is wrong on the properties as a perspective buyer I’d like to know...
Hi everyone! Parents not used the boiler since 2013/2014, since installing a new wetroom for them they have now decided its worth getting the boiler running again. The only reason it has not been used i so long is the the zone valve kept getting stuck (would have fixed this myself if i knew!)...
Hi - I'm a reasonably experienced DIY plumber but just can't work out why the last new rad I've installed is cold - would really appreciate your help please. I've extended an existing 'run' of radiators - the last one on the run ( in downstairs kitchen) is cold. The first rad added is...
