Discuss Nest wiring question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
JTplumbingservices
If this is going into an existing system with a programmer and room stat is it just a case of wiring the nest stat into the old room stat and the heat link into the old programmer wires?
Cheers
What system combi or s plan
Best to remove the wiring and fit receiver below boiler you need to be gas safe to do this if the wiring is behind the main cover
I passed my gas on the 19th of December.. just waiting on my certificate now
Ive been a time served plumber since 2006 but our company didn’t do gas work so we had to sign something to say I wouldn’t be able to sit my assessments.
My current company is the first since then who agreed to put me through it so now I’m trying to educate myself on heating controls, fault finding etc
Reply to Nest wiring question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised valves simple bi-metal thermostat on wall in flat with 4 standard TRV's rarely used so not worried about the flat, and main house has Nest Gen 3 in the...
Hi Fellow Engineers I've attached a wiring diagram I've just completed, I wanted to make sure I've got it correct. Looking to install 2 Nest thermostats to a Worcester combi boiler. 1 Zone is radiators and the other is UFH, with pump on manifold Would be grateful to receive feedback. Thanks
Hi everyone, Just wanted to share my experience with "upgrading" an S plan setup to Opentherm and Vaillant Control Center (VR66). There are a few threads on a few different forums but I wanted to share a full write-up with all the steps needed, benefits and costs. Overall, I fully recommend...
1K
Hi all, I have just bought a google nest 3rd gen thermostat to be connected opentherm. I currently have the baxi ifos rather comp fitted. I was told that it was either one or the other, but baxi technical dept have said I can wire an opentherm controller alongside the ifos system. Boiler is...
Hi, I am trying to link a Hive heating & hot water dual channel receiver to an old Vaillant THERMOcompact VU GB 242/1 E system boiler. It has an internal programmer that is similar to a time switch 120 (plug in seven day programmer) This programmer is connect to a terminal strip using 345 (three...
