Discuss MORE SHOWER POWER!!!! in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
Tags:
  1. breadpudding
    breadpudding New Member
    OLD HOUSE WITH GROUND FLOOR GRAVITY FED SHOWER AT BACK OF PROPERTY- LONG WAY FROM TANK IN ROOF!!
    MIXER TAPS ON BATH WITH THERMO VALVE.
    CONVENTIONAL BOILER.
    BOILER NEAR BATHROOM
    CYLINDER UPSTAIRS.
    HOW TO CHEAPLY INCREASE SHOWER DRIBBLE!!?? PUMP?
  2. Craig Watson
    Craig Watson Plumber GSR Top Contributor!!
    Define cheap?
  3. breadpudding
  4. breadpudding
    LESS THAN £200.00
  5. Craig Watson
    If the shower has independent feeds which are easily accessible and your confident in doing it yourself then yes it's possible for you to supply the materials required for less than £200. If your wanting to get someone in to do the work, then I would increase the amount you want to spend.
  6. breadpudding
  7. breadpudding
    what about the SP2B shower booster?
  8. Craig Watson
    Never fitted them so can't comment, I've seen them online @ £120 but that only appears to be one, for a gravity mixer you will require 2 which already takes you over your limit and doesn't include install.
    @Rob Foster@Rob Foster should know more about this product.
    • Like Like x 1
  9. Riley
    As mentioned above are you doing it yourself? Keep in mind that pumps will also wear out so you will be looking at spending the same again In a few years time. If you fit a proper pump then it will also need to be piped correctly and otherwise any warranty will be instantly void, additionally you need to consider your water storage if you have a pump you will use more water so you may need a bigger tank in the loft in order to replenish it
  10. Coby kenny AGUILAR
    Coby kenny AGUILAR Member
    If the water main is close by and consumer unit, you'd probably get a cheap electric shower for around £200 - £250 supply and fit
    You can also get a positive pump for around £100 parts should be okay as feeds are coming from upstairs, depends who fits it for what the labour is.
    If you could double your budget you'd have something more robust and that'll last a lot longer.
    These cheap electric showers and pumps work harder than they can cope with, they get really hot and finally start going wrong
  11. Rob Foster
    Rob Foster Top Contributor!!
    There is a double pump unit available. contact Alan Wright
    [email protected]
    he is the inventor and trades in his unit, or contact Flowflex direct at Buxton they manu the unit and also sell them
Loading...
Similar Threads - MORE SHOWER POWER Forum Date
Why aren’t plumbers plumbers any more? Gas Safe Register Forum - Public Forum Apr 15, 2019
What trade should get paid more ? General Off-Topic Chat Mar 21, 2019
