Discuss Mixer Tap with cold water feed only in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All,
I got a great deal on a basin and tap recently, the only thing is, is that I only have a cold water feed. Now obviously the mixer takes two inputs but i was wondering what my options are in terms of input.
I'm ok that it's only cold water but i was wondering if there's a blanking fitting or threaded Y piece that i can attach the mixer feeds into one?
Thoughts appreciated.
TIA
yes you need a bsp plug either direct into the tap or on the flex
Reply to Mixer Tap with cold water feed only in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied from cold water tanks in the loft. It is a vented system. However, in a basement flat and a ground floor flat cold water supply to bathrooms is...
Hello, I have a few mixer taps to install in bathrooms and kitchen. The kitchen tap also has a wondering spray arm capability. On researching something else, i stumbled across people saying that a check valve should be placed on the cold mains feed. How can I tell if the mixer taps/spray arm mix...
Got intermittent hot water coming the from a combi boiler to kitchen mixer tap when it hits the T junction for the upstairs bath it's hot, but on the other of the T junction to the kitchen mixer tap it's stone cold, anyone any ideas ?
Hi there, All was good until one day the hot water suddenly started running quite a lot cooler. Putting my hand on the output at the boiler it's still hot there so I'm guessing there's a problem with cold water feeding into the hot water somewhere along the line. I have mixer taps on two...
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air gap as I was having dripping from the pressure relief valve. Since then I've lost a lot of pressure from the hot water feed to my shower. The rest of...
