Discuss MCZ Pellet central heating system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can you see the micro switches working in them ?
I didn't end up spraying them - took the covers off and watched them as they switched on/off - both two way valves are working fine by the look of them.
The only thing I cant work out is why the pumps aren't pushing water around. As I said earlier they did light up - but haven't done since. I've been around the place, set the thermostats up/made sure that every switch I can find is set to on - made sure that the return valve on the heating loop is open etc etc.
Completely stumped.
Ok , we all need to fault find on his one, r u sure the pumps are actually pumping , often when they are bust,seized the impellor head will rotate but no liquid wil be moved , sorry about underlines I do not know how to switch them off
Chk
Completely stumped.
Is there voltage to the pump? When the valves have motored?
My take on the problem......
Those grundfos pumps are absolutely Rubbish, they were a quick and late design to get on the modulating pump market. Whip it out !!!!
The leds will be lit, but the actual performance will be far under.
Reply to MCZ Pellet central heating system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
