Discuss Mainsboost for unvented system in the Central Heating Forum area at UKPlumbersForums.co.uk.
  1. Stants
    Stants Member
    Hi all for a loft conversion I’m renewing my heating system to an unvented one ( new boiler , Mega flo or similar ) all located in the new loft space , I’m on the cusp regarding pressure and flow rate so was going to upgrade mains into house but it was suggested to me to have another tank that stores ( or helps with ) pressurised water I’ve had a look online and would it be a mains boost system ? I’m wondering if anyone had any info about these ie are they a good option / any good .. all info great fully received
  2. Riley
    Why did you give up on the mains idea?
    • Like Like x 1
  3. ShaunCorbs
    Problem is they run out too fast
    • Like Like x 1
  4. Stants
    Stants Member
    I haven’t given up it was just suggested as an idea it’s possible rather than dig up the garden about 40 foot to put the new mains in
  5. Riley
    Depends how much space you’ve got to play with. Mains I think would be preferable if water hoard can confirm that by doing so you are likely to achieve a better flow and pressure
    • Like Like x 1
  6. Stants
    Stants Member
    Yeah it was suggested I could upgrade the mains and still be no better off if there was a bit of a surge for water ie mornings and evening
  7. Stants
    Stants Member
    I think I could make enough space but depending how big the cylinder would be I guess I would end up in the property with one bathroom and a shower in the loft so it’s not massive
  8. Riley
    Is that from water board or hearsay
    • Like Like x 1
  9. Stants
    Stants Member
    Ah ok does it take long for it to get back up to pressure do you know ?
  10. Stants
    Stants Member
    Only hearsay
  11. Riley
    Ask the waterboard
  12. ShaunCorbs
    Mole it ?
    Only need two holes then
    • Agree Agree x 1
  13. Rob Foster
    Rob Foster Top Contributor!!
    The basic problem here is our increasing mains water useage.
    We Uk get thro 250 litre per day UsA 400 plus and we are headed in that direction. So the short term solution is to fit decent mains suction pump
    eg Grundfos wras approved. stuff the upgraded water main.
    But when your neighbours get theirs installed you will be back to square one. Then get a wider mains supply installed ..loads of £ then your neighbours do same ...back to square one again. Now do not think I am a greeny etc I am not, just explaining how your journey will unfold...Rob Foster aka
    centralheatking...high level intermediate water storage is the answer....ie the old vented conventional domestic heating and hotwater production system
    • Disagree Disagree x 2
  14. ShaunCorbs
    Only boost it to 12lpm so no good to anyone
  15. Stants
    Stants Member
    Ok cheers
Loading...
Similar Threads - Mainsboost unvented system Forum Date
Unvented Cylinder Tee Off Plumbing Forum Saturday at 3:44 PM
Combi or unvented, which is cheaper to run Plumbing Forum May 15, 2019
