Discuss Lever tap with H & C feed changed to Non Concussive. Is a TMV required in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello
We have 3 lever taps that need to be changed to Non Concussive for the customer.
The hot feet is from a small water heater and cold off the mains I think.
The Non Concussive Tao obviously only has one feed into it.
So my question is do I need to no fit a tmv to mix both hot and cold or could I just turn the heat down on the water heater and connect just the hot.
Thank
If you turned the hot water heater down to a safe temperature for the tap, you'd have to have the stored hot water at 38 / 40 c,
Does that stored hot water temperture ring any bells?
Come across a problem.
Any suggestions would be appreciated o_O. The original tap has a larger base. We now have some gaps.
Stainless steel repair washer
Reply to Lever tap with H & C feed changed to Non Concussive. Is a TMV required in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We have had an ongoing issue with low hot water temperatures in a school. During the recent repair of a leak, the plumbers isolated the hot water to fit a new bit of pipework and found that water wouldn't stop running until the cold boosted water was also isolated. Given this, it would seem...
Hi I have a leak on my kitchen tap it is coming out off the bottom of the cold lever. How do I get the lever off? Also would this tap have a cartridge in the cold & hot or will it be just tap has had it & I need to get a new one?
Hi - recognise this a bit of an odd one. We have an old failed mixer valve which we need to replace. This valve actually predates a temperature controlled boiler, so the mixing functionality is irrelevant, since the cold water pipe is isolated/off. I'd ideally like to replace the shower valve...
Hi everyone, I need to replace the kitchen tap, all my neighbours have two single taps in their kitchen and bathroom whereas I have a single lever tap in the bathroom and kitchen. Due to living in a flat and having a shared water supply I was advised to get a dual flow tap for the kitchen so...
Hi there, All was good until one day the hot water suddenly started running quite a lot cooler. Putting my hand on the output at the boiler it's still hot there so I'm guessing there's a problem with cold water feeding into the hot water somewhere along the line. I have mixer taps on two...
