Discuss Least Bulky Plastic Fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I want to extend a radiator using either PEX or HEP20 pipe, which type of pipe has the least bulky fittings as I need to fit under floorboards.
TBH there all about the same just hep slightly smaller dia
dont think the fit / work with plastic pipe
Tectite Sprint or Conex Cuprofit are the least bulky. The Tectite fittings work with PEX if you use the correct liners/inserts. However I recently had one leak on me, which is the first out of many that I've used and I'd thoroughly test your system before putting your floorboards back down. Tectite are non demountable and are permanent, Cuprofit are demountable with their special tool.
You can also use compression fittings with plastic pipe, but use copper olives, not brass olives.
Pegler Yorkshire - Sprint
Just to clarify Cailean's detailed reply; Conex Cuprofit are only for copper pipes.
I believe that Wickes' own brand copper pushfit is Cuprofit repackaged as it appears exactly the same (and Toolstation sells Cuprofit). It is helpful to know as sometimes one has stock that the other doesn't (eg. the Wickes demounting tool, which works with Cuprofit branded fittings).
Don't forgot to also use an insert if using compression fittings with plastic pipe (in the case of speedfit, not the speedfit "superseal" insert).
As above, don't forget to use an insert with just about all pex type plastic push fit pipe per mi's.
And, if you're using compression fittings on jg speedfit don't use the "superseal" insert, just use the "basic" inserts in this case.
(Personally I think hep2o fittings look better, although they shouldn't really be seen, they feel like better quality and the fittings are slightly smaller)
Floplast fittings are one of the smallest speedfit. You use a clip to lock the collar. Some people prefer the look of them too. Ready available at Screwfix.
I haven’t used them for a while as the company I work for don’t use them. Hep20 seem to have the longest warranty periods from what I remember.
I have used them without issues in the past. But I’m talking 10+ years ago now.
I work with what I am supplied with.
If you do the proper tests once installed you will know if you have any problems.
If you do use them pressure test them and you will know if you have any issues.
As stated unsure of the quality these days.
I often go into properties where they have been installed for 10+ years and still holding.
Have a look at Buteline. Very small fittings. Have transition coupling in both solder and compression to join their pipe which is 16mm. Fitting is crimped no O rings or inserts simple joint .
Reply to Least Bulky Plastic Fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
