Discuss Leaky aluminium shower frame in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. alichambersUK
    alichambersUK Member
    Hi - I have had a leak from my shower which I cannot seem to fix.
    I have re-siliconed around every joint I can find - the blue lines on the images are close to where I have siliconed. And on the pan corner by the blue arrow.
    I have black tape over areas to test where leaks may be.
    When I pour water over the black tape area, water seeps out - although less than before - from the circled area.
    I'm out of ideas - any suggestions?
  2. Craig Watson
    Craig Watson Plumber GSR Top Contributor!!
    Shouldn't really be applying silicone on the inside of the shower screen, up the vertical wall posts is usually fine and some manufacturers specify this, but never seal round the base of the screen on the inside.
    What this does is trap water in the wall profiles and then water will leak out the area you've circled in blue.
    • Agree Agree x 2
    • Useful Useful x 1
  3. Craig Watson
    Actually, why have you removed the silicone from the outside of the screen?
  4. alichambersUK
    Thanks Craig. That's useful to know.
    I applied silicone inside to try and stop the leak, as the leak was there before.
    Any other ideas on where to look?
  5. alichambersUK
    I removed the silicone to try and find the leak source - a hole had appeared in the silicone where water was seeping out (in the circled area)
  6. Craig Watson
    This looks a little suspicious, your tray should be fully tiled in, then sealed, then shower screen fitted and screen sealed. It's common for diyers and even some plumbers to fit the screen and then seal up to it. If this is the case and the pic suggests it might be, I'd recommend removing the screen all together, re sealing the tray then refit the screen and re seal the screen on the outside only.
    • Like Like x 1
  7. alichambersUK
    OK mate, cheers. I may end up doing that.
    If any more photos close up would help, say and I'll post...
  8. alichambersUK
    As I'm only a basic DIYer, would a plumber be best to do this?
  9. Craig Watson
    Depends on how competent you are. It's not difficult by any means. The hardest part is getting the screws out of the wall profile without either rounding them off or snapping them. Also if the wall profile has been stuck back to the wall with silicone then you may bend them getting them off.
  10. Best
    Best Trusted Plumber
    The frames are really not well sealed from factory and designed to drain water to inside of door, so just apply bead of silicone to the outside horizontal joint and vertical joints.
    Joint between tray and tiles behind door is critical to seal, as Craig mentioned
    • Like Like x 1
  11. alichambersUK
    Any chance you could describe how to do this in a bit more detail - I'm learning so a bit of a newbie.. ta :)
  12. Best
    Bead of silicone at tile to tray joint where door to go before screwing on door profile.
    Use good quality silicone and often best clear silicone with chrome doors.
    Just cut the tip of nozzle a straight cut big enough for a small width of bead.
    When rubbing the silicone smooth, use a Fuji kit (which is a kit that has shaped rubber pieces that remove the silicone to a neat bead)
    • Like Like x 1
  13. alichambersUK
    Thanks everyone for replying here - it has helped me a lot :)
    • Like Like x 1
  14. Steve weightman
    Steve weightman GSR
    It doesn't matter how much silicone you use if it's not done behind the wall profile at the bottom to the tray your wasting your time hope this helps
    • Agree Agree x 2
  15. YorkshireDave
    YorkshireDave Plumber Top Contributor!!
    Before you put more silicone anywhere, you MUST remove ALL of the old silicone AND it must be fully dry. Romove it with silicone eater & then use isopropyl alcohol to clean too.
    Have fun
