Discuss Language Setting Problem - Vaillant Ecotec Plus 824 in the Plumbing Forum area at UKPlumbersForums.co.uk.
  1. Joan
    Joan New Member
    Dear All
    Help! My boilers settings are in Polish and the manual online has a different settings box to mine (cf picture). I have tried google translating the options that come up but none of the words translate to 'language' in English. Help greatly appreciated.
    Best
    Joan
  2. RayW
    RayW New Member
    Does this help .
    If you unintentionally select a language that you
    cannot understand, you can change it again as
    described below.
    > Press the right selector button and the plus button
    simultaneously and hold them down.
    > Press the fault clearance key for a short time.
    > Keep the right selector button and the plus button
    pressed until the option for changing the language
    appears on the display.
    > Select the language of your choice using the minus key
    or the plus key.
    > Confirm the change by pressing the right-hand selector
    button ("OK"
    • Like Like x 1
  3. Joan
    Joan New Member
    Fantastic! Thank you so much!
  4. RayW
    RayW New Member
    Unfortunately this can be the result of employing a Polish Plumber!
Loading...
Similar Threads - Language Setting Problem Forum Date
Shower running lukewarm on hottest setting Plumbing Forum May 14, 2019
Honeywell ABV setting Central Heating Forum Mar 28, 2019
