Discuss Just Need Boiler Identification??? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
DjClubber
I know this is a Vaillant, does anyone know the actual Model for this please?
I have just done a Gas Safety Inspection on it. But no idea what Model to put down on the CP12 LOL... For the age, good CPA, Flame Picture etc before write it out, want to check correct Gas Rate etc. its burning at 8.9kw net. Just want to confirm against MI...
Didn’t you take the case off ?
Did you check underneath or ontop where the flue is ?
Yes 100% i checked on the top where the flue is. Just a vent nipple and vertical flue, aps also there and exp vessel. NO DB. Underneath just a massive whole no base.
According to the master that is a VC 142E or 182E system boiler.
He also said - "That red light indicates ignition PCB, low water, no gas" & "Look at the gauge... it's on ZERO" "Needs water, possible overheat has tripped..."
It is a loverly bit of kit built like a tank & looked after will outlast these modern ones.
Absolute DIAMOND... Thats exactly what it is. Just pulled up the MI PDF... Thanks...
I rectified all the errors and topped the system back up. Just done a Gas Safety on it, needed to know the Model. Its the VC 112 thermoCompact. TY... Appreciated...
Send us your gas safe reg no and I will sort it
Reply to Just Need Boiler Identification??? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Does anyone know a good, not super expensive, leak detection company in the London area?
