Discuss Its not Plumbing but very Informative in the Plumbing Forum area at UKPlumbersForums.co.uk.
Tags:
  1. Rob Foster
    Rob Foster Top Contributor!!
    E54D7DC0-9FF9-41F5-A438-5F94831B9D53.jpeg We are expanding our garden and there are 12 6 ft concrete posts to go. Hire shop dropped this off just, its ace and really works...a hydraulic post lifter takes out post and the concrete plug in one go...Nice to use a dedicated machine that works
    • Like Like x 4
    • Agree Agree x 1
    • Friendly Friendly x 1
  2. ShaunCorbs
    Never ever seen one of those before bet it beats doing the wiggle or getting the breaker out
    • Like Like x 2
  3. Best
    Best Trusted Plumber
    Didn’t know that existed. Just shows we need to keep informed.
    But that will not work on broken or rotten wood posts in concrete
    • Like Like x 1
  4. ShaunCorbs
    You could drill an expanding anchor in and try that ?
    • Like Like x 1
  5. Best
    I suppose you could.
    I spent hours of very hard graft using a breaker over 2 days trying to remove strong concrete that had the stumps of metal posts due to a metal railing accident damage.
    Staggering how much work it was.
    That machine above might have done it
    • Like Like x 1
  6. ShaunCorbs
    Yep tbh easier to dig around and wiggle them out unless it’s too much damage
    If you need to breaker them out drill a load of holes in the concrete first eg 10mm makes it’s alot easier
    • Like Like x 1
  7. Best
    Builder had surprisingly used large amount of very strong concrete mix.
    Probably should have tried drilling it to weaken it
  8. ShaunCorbs
    Least you know if there’s any others there not moving :D
    • Funny Funny x 1
  9. Best
    Absolutely! To be fair to the builder, he does use the best materials.
    High speed car impact folded the steel posts as if they were light metal, but the concrete bases remained unmoved.
    Wonder if that machine would help remove conifer tree stumps?
  10. ShaunCorbs
    Maybe worth a try
    • Agree Agree x 1
  11. Best
    Obviously going to have to chop the roots off as much as possible first.
  12. ShaunCorbs
    Rec saw in the ground aslong as you know what’s below
  13. Rob Foster
    It comes with a claw which can be attached to take out tree roots etc..when we have got the posts out ..then we will use the
    scissor thing to what else it will
    do....I will report back with piccys later tomorrow
    • Informative Informative x 1
  14. Rob Foster
    yes but this thing just lifted it all out no prob...we did leave the hose on all last night to
    emulisify the ground
    chking
    • Like Like x 1
  15. rpm
    rpm Trusted Plumber Top Contributor!!
    First thought was stump remover, same design.
    • Like Like x 1
Loading...
Similar Threads - Plumbing very Informative Forum Date
Servicing Tools is a very important part of any Plumbing business Plumbing Forum Jun 30, 2019
Plumbing schematic symbols? Plumbing Forum Monday at 6:25 PM
