Discuss IntaKlean Service/cleaning in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone. I'm hoping somebody will be able to offer some advice. I've recently moved home and above the boiler is a Inta Klean triple action magnetic vortex filtration system installed. Doing a bit of research I now understand what this gizmo does but it seems to clean it the engineer needs to unscrew the bottom of it. The problem in my house is that the way it's been installed means you wouldn't be able to unscrew it, as the bottom has been wedged between the boiler and a kitchen cabinet. Is it possible to remove it to clean in a different manner than the usual?
Any help appreciated .
Many thanks.
Yep obviously make sure you turn off the butterfly isolations. Might be prudent to replace the washers when you put it back. Obviously keep in mind when you undo the bottom nut quite a lot of the water will try and escape the filter. just Be warned. It will stop though. If you can get the lid off in situ then a wet vac would be the cleanest way to get the water out before removing the filter
Reply to IntaKlean Service/cleaning in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The existing pump flows downwards. The manual for the proposed replacement recommends that it should pump upwards. This would involve rearranging the flow &...
Please excuse the long story! so, my central heating kept tripping the fuse in the consumer unit. I read that moisture in the boiler could be the problem and had a look at the flu which, it was evident, had been leaking water into the outer flu and back into the boiler. I chose the top rated...
2K
I have had a new 32 CDi Compact WB boiler fitted recently,along with a Greenstar filter. The filter has been fitted very high up, about 4-5 cm from the ceiling. Watching youtube videos, it seems the lid has to be unscrewed and the filter lifted out from the top. Can the filter be unscrewed (top...
2K
My boiler is an Ideal Icos HE30 boiler. This supplies the central heating and a separate heat store - in other words a big cylinder - for domestic hot water. It is not a combi boiler. The boiler is 10 years old and it has been serviced by the original installer each year since installation. It...
5K
Hi all, I moved into a 3 bed detached property June 2018, turned the heating on in the October and found the living room rad didnt come on. The system is not a combi boiler, i have an emersion heater upstairs, it does have a magnetic filter next to the boiler. I drained some water out of the...
1K
