Discuss Identify a "concealed triple shower valve" in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi
The temperature control on my "concealed triple shower value" has started to play up.
The value is behind a partition wall with only access to the front and I can not find any name or serial number on it to help me identify it. Does anyone recognize this value? It looks to be quite old. Its layout is
shower outlet
(shower control)
hot input concealed (temp control) concealed cold input hot adjuster cold adjuster
( bath control)
bath outlet
Any help will be greatly appreciated
Regards Les
Hi Simon
Thanks for your help.
The cartridge and the assembly it is mounted in, looks very similar to the Bristan Sirrus range. I am reluctant to completely remove the cartridge without having a spare, as I am unable to isolate the shower from the rest of the house. Cold water feed to the shower appears to come straight out of the wall, feed directly from main stopcock.
Unable to access the pipe work as it is located behind a partition wall. I have got a better quality image using a digital camera
Reply to Identify a "concealed triple shower valve" in the Plumbing Jobs | The Job-board area at PlumbersForums.net
