Discuss How to remove diverter valve handle and faceplate in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. Cassas00
    Cassas00 New Member
    My shower hose connection has popped out of the diverter value
    You can see it here: Imgur
    I've found the manual for it, here: Imgur
    But I have no idea how to remove the handle and faceplate so I can tighten the screw into the notch on the shower hose end connection.
    Any ideas?
  2. Stu-B
    Stu-B Active Member
    If it were me, i’d Be looking under the white disc on the handle, see if it pops out or unscrews to reveal another screw which when unscrewed will allow you to remove the handle.
    Then it looks as if the valve cover is just a push fit, maybe try to prise it out using the small notches either side?
    Difficult to say for sure but I’d definitely look at that first
Loading...
Similar Threads - remove diverter valve Forum Date
Customer has removed tray etc and wants tiled floor no tray Plumbers Arms Jul 10, 2019
How to remove gas fitting from wall Fittings & Pipes Jun 15, 2019
