Discuss How to change a water filter cartridge in the Plumbing Forum area at UKPlumbersForums.co.uk.
  1. Trac
    Trac Member
    I was wondering if anyone can give me simple instructions of how to change an Acquifier water filter cartridge?
    I believe I have to turn the water off first, under the sink, and need to locate a quarter turn valve.
    I was wondering if anyone can help me locate this valve or a point under the sink where I switch off water so I can replace the cartridge.
    I assume I also need to switch off the mains water point.
    H under sink water cartridge.jpg ere is an image of under the sink - the think blue piping leads to the cartridge that needs to be replaced.
    Thank you!
  2. Ben-gee
    Ben-gee Plumber Top Contributor!!
    It will be fed from the mains water supply, so just turn that off if you can’t find a valve locally. Either st your stopcock or out in the street.
  3. ShaunCorbs
    You can try turning the washing machine valve off that feeds the filter sometimes they work sometimes they stick if not as Ben says mains off etc
  4. Harvest Fields
    Have some kitchen roll or a bowl to hand to collect the water and open it slowly to see if it has held.
  5. ShaunCorbs
    or open your filter tap and turn the valve off if it stops your good to go as harv says have a towel ready for any drips etc
    • Like Like x 1
  6. Trac
    Trac Member
    Many thanks all. This is really helpful. I shall try the suggestions and certainly turn off at mains. I can't see anything understeer sink that I would need to switch off. I assumed I would need to turn off a valve here but don't know what I'm looking for....I hope that turning off at mains would suffice and then do a quick filter replacement. ..
  7. JCplumb
    JCplumb Plumber
    The isolation valve is right there, middle left on the pic. It's a tee with a blue handle.
  8. Trac
    Trac Member
    That's really fantastic JC. Brilliant . Many thanks. It's much appreciated. I shall give the valve a turn bit will switch off at mains as extra precaution. :D:)
Loading...
Similar Threads - change water filter Forum Date
Greenstar 30cdi system leaking under heat exchanger Gas Safe Registered Plumbers Only Jul 5, 2019
Scaled Heat Exchanger? Bad enough to cause problem? Central Heating Forum Jun 25, 2019
