Discuss How to change a bath tap cartridge in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. kat77
    kat77 New Member
    my bath taps have no obvious grub screw so how do I get it off to replace the cartridge? Is it as simple as the top just pulls off? I don’t want to break them! There is no makers name on them for me to contact. They are quarter turn taps. Thanks
  2. Harvest Fields
    They probably pull off email Hudson reed a picture it maybe one of theirs.
    • Like Like x 1
  3. steadyon
    steadyon Active Member
    Try Hudson Reed as Harvest Fields suggests, or try Shower Doctor.
    However, that's a three hole mixer. You'll almost certainly have to take the taps to pieces under the bath to get the cartridges out. If those taps are in the middle of the long edge of the bath you may well need access from the other side of the wall or have to take the bath out.
  4. kat77
    kat77 New Member
    Thank you both for your help, I messaged Hudson reed who responded very quickly and told me they should pull off! Thanks again :)
    • Like Like x 1
  5. Harvest Fields
    You’re welcome mate. Make sure that you pop back again.
    • Like Like x 1
    • Agree Agree x 1
  6. YorkshireDave
    YorkshireDave Plumber
    Even with a three hole, in the UK, I've never had to remove a body to change cartridges.
    • Agree Agree x 1
Loading...
Similar Threads - change bath cartridge Forum Date
Expansion vessel change on a viessmann 200wv Gas Safe Registered Plumbers Only Tuesday at 5:18 PM
How to change a water filter cartridge Plumbing Forum May 14, 2019
  1. change both taps cartridge
  2. how to change cartridge in tap
