Discuss How do you hang a radiator ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Rob Foster
When the floor and building are lala,
1. trust the spirit level
2. eye it in
see the results of 1. looks goofy
shelf is level floor is lala
centralheatking
I would hang the new rad on dead level and put a couple bar stools in front of it to hide it. ;)
Actually Harvest has sensible idea, - pass the final decision onto the customer.
It could be worse - the shelf could be also off the level in opposite direction to floor!
The eye will always be convinced that the plumber is an idiot and rad is miles off level, as builders don’t put shelves and floors in off the level. :)
I always set mine off level a smidge towards the air bleed
Sometimes the room is so completely off whack putting it dead level without reference to the rest of the room will spoil the appearance of the whole room. Granted other elements can be more easily straightened out but until they are it'll look wrong. and if it's opposite the door it just won't do.
Always level, I couldn’t sleep at night knowing I installed something on the p@ss
I had this pig of a customer called me back to re hang the rad I installed "except level this time". I walked in with my level and put it on the rad which was dead straight then put it on hes window ledge which wasnt and smirked at him. Trouble is with a long rad if you follow the window the floor will show it up.
Reply to How do you hang a radiator ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Fitted unvented hotwater cylinder building control looking forms signed it off job was in england i am qualified northern ireland send out a form to fill in what do u need to sign off in england as building control said they dont give out forms like they do in northern ireland
