Discuss Hot water in the expansion tank. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
bcampestris
My open system central heating header tank was getting really hot. I've turned down the pump and adjusted the balance between the hot water and central heating zones. This had reduced the water to 'tepid'.
However, every time the heating thermostat cuts out I still get a splash of water into the tank. Is this normal? I suppose the splash is about 1/8 of a pint.
This is known as pumping over and is incorrect. Left uncorrected it will lead to corrosion in the system. It may be due to a partial blockage in the pipework or it may just be that the vent needs raising.
Mike
Reply to Hot water in the expansion tank. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
OFFICIAL SPONSORS
OFFICIAL SPONSORS
