Discuss Hot pipe run outside in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hi everyone,
We’ve got an unvented cylinder in an outbuilding. I need to get from here to a building next to it. There is probably 2-3 meters in which the pipe would need to run outside before going into the next building. Would this be okay? Obviously it would be well insulated? The system does have a secondary return so this could be extended to accommodate the new bit, would a secondary return 1, stop freezing as water is constantly flowing and 2, would it cool down too much on the return and cause issues? Thanks in advance
Reply to Hot pipe run outside in the Plumbing Jobs | The Job-board area at PlumbersForums.net
