Discuss Honeywell stat advice in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can someone recommend me a simple to use remote thermostat?
Preferably a Honeywell.
Thanks in advance
honeywell t3r
What's the difference? (Never had a stat so forgive my ignorance)
One is a thermostat that will work alongside a programmer, the other is a room thermostat where you can programme different temperature set points through the day, eliminating the need for an additional programmer.
The latter sounds like what I need, can you recommend one?
The only Honeywell stat Ive installed in a long time was the lyric t6r, nice thermostat but not the simplest of stats to use. If you want to stick with the Honeywell then I'd trust the opinion of Shaun and Chris. If you just want a simple to use stat then I can recommend these
Neomitis Wireless Digital Room Thermostat - RT0 RF | Digital Room Thermostat | PlumbNation.co.uk very easy to use and install. However, as you have to remove the boiler cover to wire the stat into the boiler, you will need a gas safe engineer to install it for you.
t4 is a programmable room stat eg timer and stat in one
t4r "" "" "" "" "" but wireless
t3 is a room thermostat
t3r "" "" " " but wireless
Reply to Honeywell stat advice in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
