Discuss Honeywell cm921 problem, manual switch on ok autmatic not working. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just turning on central heating for the first time this year, adjusted timings and temperature and switched to automatic mode, and heating turned on out of specified on times. Left it running for a while and then turned off, after a while returned slider to automatic, within specified times and signal sent picture flashed on screen, but no response from receiver box or igniton. Boiler comes on ok on manual setting. Replaced batteries in unit. any ideas please ?
You can re -pair the control to the receiver I believe it explains it in the instructions.
Reply to Honeywell cm921 problem, manual switch on ok autmatic not working. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
Wishing everyone on tgmhis forum a very happy Christmas!! I am working on a combi boiler which has problem with heating only. Water is heating normally. Here are the symptoms 1. Signal from thermostat is not firing the boiler. It does not make any sound when heating is on from thermostat. 2...
So I've used a wireless thermostat to activate my heating since installation, but it's just stopped working (Blank screen, no new battery's fixed fixed it) The wall mounted programmer screen flash's no signal, like it's searching for the wireless thermostat, I cannot turn the heating on at all...
2K
Good Afternoon all, I am hopeful someone may be able to offer some guidance on the following. In the home we have a gas boiler (serviced annually, October time) providing hot water to the CH system which is split into 3 zones (Honeywell 2-way valves) and it also heats the HW tank (Tribune...
Would like some help please as my Drayton Wiser system is a mess. I had 2 TRVs in the lounge, one in the main bedroom, the rest of the house - 6 other radiators and 2 bathroom towel radiators are just normal valve s. We live in a 4-bed, 3 storey house, as converted loft. Common problems were...
Conditions: nearly 10 year old boiler WB2B, heating mode off, DHW on or also in standby, Boiler shows no fault LED on, no new fault logged, room thermostat deactivated. Boiler gets odd attacks of suddenly turning on the fan 100%, then (gas valve and ignition are clicking?) potentially tries to...
