Discuss Hi.... and a combi boiler pressure drop query! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi
Just joined forum as amateur DIY guy and wonder if anyone here can help me. I have a Vaillant 828 Turbomax Combi boiler which I’ve had for about 16 years old. I monitored the pressure yesterday & saw that it was quite low (around 1) so I topped it up to just over 2 and when I went back to it today it's dropped down to 1 again which made me wonder what’s wrong…e.g. an issue with the expansion vessel, fault on pressure gauge, leak, etc. The boiler still seems to be working ok still too. Thank you in advance for your help/comments. Tony
ok thanks so it was just below 1 and i put it up to just over 2 (tricky as have to turn screw underneath and cannot see gauge when topping up!) and the next time i looked it was back down to 1
I know i have an issue, thought someone here might help the diagnosis
Go round and check for leaks on the rads and visible pipework. If you find them repair them If you don't find any then call someone in as you may have a fault within the boiler and you shouldn't be touching inside there.
Probably nothing wrong but a simple weeping joint somewhere. By topping up to just over 2 what happens is the boiler fires up & the heated water will expand, the pressure will rise and if it goes up to 2.5-3 then the pressure relief valve opens and dumps the water outside to protect the boiler and that is why it goes back down to 1 the next day. Just keep topping it up to 1 if it drops to 0.5 and either get someone in to check it all out or put up with it till you are replacing it all.
Reply to Hi.... and a combi boiler pressure drop query! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Good afternoon, I am experiencing a pressure issue with my heating system and was hoping to receive additional insight as to what the problem could be. We have a biomass boiler and stratification tank set up and recently had an issue with boiler pressure dropping off when the system was cold...
M
Hi, we have a back combi heater. Whenever the heating comes on it seems to lose pressure within a few hours and I have to refill each morning. The boiler seems to function well, and the pressure only drops with the heating and not the water being on. Ie it started last winter and was then...
Hi, Non-professional / knowledgeable person here. I'm a Brit in Romania who volunteers for a charity building an old peoples home for needy old people. Out here competence and integrity is harder to come by in a worker, in fact it's hard to find workers at all where we are in the countryside...
I have just had a boiler, hot water tank and power shower pump replaced on advice by my plumber. I have two separate boilers, heat/hotwater systems in the house. This boiler was replaced by a combi boiler as it only heats the lounge and master bed and provides hot water to en-suite bathroom and...
Hi, Just had a "Main Eco Compact" combi boiler installed as the Biasi one failed. It seems to work fine, gives a hot bath, i dont ever use the radiators or kitchen hot tap. (no point in upping the landlords gas bill for no reason) On day 4, the pressure is below 1. I filled it back up to >1, but...
