Discuss hi all,i have a alpha intec 28x which will fire in test mode in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, the boiler is a alpha intec 28x which will work in test mode but not in normal mode and it gives plenty of hot water
Reply to hi all,i have a alpha intec 28x which will fire in test mode in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
Wishing everyone on tgmhis forum a very happy Christmas!! I am working on a combi boiler which has problem with heating only. Water is heating normally. Here are the symptoms 1. Signal from thermostat is not firing the boiler. It does not make any sound when heating is on from thermostat. 2...
Hello, I am looking for a heating engineer to diagnose and resolve an issue with my Vaillant EcoTec 832 combi boiler. Job Location: Copeland Rd, London. Job Description: Problem: The boiler is not providing heating under normal conditions, although hot water supply is fine. Interestingly...
Hi all, I have a wallstar combi oil fired boiler. We got low on oil a couple of weeks ago but didn't run out. Since we've had our oil delivered the boiler won't fire up when hot taps are turned on so no hot water. The boiler fires up periodically to heat water but not when we turn on taps. I...
M
Hello, One year ago I just bought model 100-W 35kw combo for central heating and hot water..and after one year using this central heating ECO mode stop working on DHW, Comfort mode work well for few mints and coming again cold water and after again hot water, but ECO mode stop working at...
Hi, I have a Vailant EcoTec Boiler with a Megaflo. These are controlled by a Honeywell controller. I have one 3 port diverter, where one of the outputs goes to a 2 port diverter prior to the Megaflo (I believe this is some safety feature). I have run into an intermittent problem where some...
