Discuss Help with mystery seal in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello everyone,
A few weeks ago I knocked over a 110mm stand pipe for the septic tank in the garden, breaking the seal adaptor. I'm really struggling to work out where to get a replacement from, please help!
I've been round a few merchants and googled all the text on the thing in various combinations, but I still have no idea where to get one. I've attached a couple of photos below, front and back, showing all the lettering on it. I tried a Polypipe seal adaptor (SWE99B) but the external pipe diameter is too small for the pipe in the ground.
If anyone can help me work out where to get a replacement I'll be eternally grateful.
Thanks in advance, Andy.
I thought with the BM marking it might be Brett Martin but doesn't look like soil pipe. What colour is the fitting in ground?
If you can't find out you can always dig down to find the next joint & replace it from there as any 110mm pipe will fit the push fit joint or as a last resort you can always solvent weld the pipe into the existing socket & forget the seal ring.
Reply to Help with mystery seal in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, My Blanco Kitchen Tap Model Swift BM1420 is leaking. Please see attached photos for details of where water leaks from. What I've done so far. I replaced the cartridge. Leak persisted. Bought some replacement seals and tried to put in place of the old ones. Here's what I did next. Remove...
So I bought my first flat recently (am in UK) and in a bit of a pickle as the bathroom has turned up lots of problems that weren't picked up by the survey. I have had loads of plumbers over, and have always carefully checked their reviews/tried to vet them as much as possible. However, I've had...
E
Hi all, Apologies if this has been covered elsewhere but I can't find an answer to my questions. I have a back boiler and gas fire which h has been serviced regularly over the years by different engineers with no issues. Last time , the guy wanted to condem it due to not being compliant with...
I have read a few threads including one by Debbie Stano that were similar to my issue but that thread stopped a while back without any resolution I could see. I'm in Brisbane, Australia but I'm after general ideas from anyone here or in UK (I realise this is a UK based site). Point form...
Hi there, Apologies for the mammoth post but my neighbours and I really need some advice... I recently purchased a flat that was built in 2016. The apartment is still under the NHBC 10yr warranty. Since moving in, I discovered that the rainwater pipe that runs through my winter garden balcony...
1K
