Discuss Help! Sewage smell & water under the house in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Please forgive my lack of experience. I am a relatively new homeowner to a fairly old semi-detached property.
For the last two months, we have had a HORRIBLE smell of what smells like raw sewage to me that comes and goes, on and off but getting worse on the ground floor of our property and is there most of the time, present in 3 out of 4 downstairs rooms.
Today, a plumber finally came and took a look under the house. Generally the rest of the house plumbing has been working fine, and the pipes outside all look fine as well (what can be seen of them).
He showed me a video of standing water (probably a couple of inches) which he said was very stagnant and very smelly, under the kitchen and living room. He said he couldn't really identify the source of it, as the walls were all dry above the water level, everything he could see was intact and his best guess (from what I could understand) was that this water was soaking 'up' through the ground from the garden side of the property, perhaps soaking through a wall and sitting at this level. His only suggestion was to take up (some rather miserable looking) decking outside the kitchen where the waste pipes run under to see whether they may be damaged below the level of the decking ( but due to miserable condition of decking it probably won't go back down again).
He also suggested maybe contacting my home insurance. What would I say? What should I do now? Can this be fixed? How can I find out what is causing this/is it really bad.. and if its just water, why does it smell to me like an open gutter?
Any suggestions/advice would be much appreciated.
Do you have any sewage lines that go under the house? If it was clean but stagnant water it would smell musty but not of sewage. If you've got a broken/burst sewage pipe under the property somewhere that would be a likely culprit.
If you can easily & cheaply get some of the decking up and dig down around what I presume is your soil stack? you could narrow it down further but otherwise I'd start off by getting someone out to do a CCTV survey of the drains.
I know there are larger sewage lines that go very close to the boundary of the house from other houses as well and they join up very nearby to our property (I live at the bottom of a cul-de-sac). I believe there may be sewage lines under the house as well.
To me, it definitely does not smell musty, but like raw sewage (and I used to live in a country where you could walk around open sewers all the time and that's exactly the smell). The plumber has said the water is clear, but its hard to tell what it is as its kind of filtered through the bricks. He says it does smell but it could be the result of it stagnating.
CCTV drain survey: how far will they look? (I'm thinking if this is a problem further away from the house and then sewage is soaking back through my exterior wall and pooling underneath these two first rooms)
This is definitely one to refer to your insurers. Just tell them the facts as you've explained them above. Don't delay because the longer this goes on the more damage will occur and the more clean up will be needed.
In future, if you smell raw sewage in or around your property don't wait weeks or months before investigating. These problems never, and I mean *never*, fix themselves and they always get worse and more costly to fix with time.
Good luck.
No , contact your utility they will always turn up examine for free bangva cctv down it , and if it’s shared sort it out fir nothing
They are the rules now Rob Foster aka centralheatking
Do not be mis led all shared drains are the legal responsibility
Of your local utility ...I Know
Yorkshire Water came out - extremely cracked soil vent pipe in the U-bend (dye tested), so its our own sewage leaking and pooling under the house - lovely.
I don’t quite understand , cracked soil vent...that’s usually dry, but the u bend ? Is leaking
What did they actually say please. You might go down house insurance route but beware of blaming subsidence as it will come back to bite you when you come to sell up. Rob Foster aka centralheatking
Fwiw. I'd think about get that in writing from them and then get my own cctv survey. If they were wrong you might charge the cost of survey back to York wart. If they were right then you've confirmed it for sure before involving insurance.
This is what they said. "CCTV'd from SVP (soil vent pipe) dye tested from toilet and this showed in floor space. The SVP rest bend is cracked."
I saw the cracks myself as they did it. I think its quite straightforward?
Reply to Help! Sewage smell & water under the house in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all I really need some help or advise….. Back story….. Some years ago my dad had an extension to his house which included a newly built downstairs shower room. Recently he had this downstairs shower room re-fitted/decorated. Quite a simple set up consisting of a sink, toilet and shower...
Hello I have a mystery, my bathroom has a sewage smell appears to get far worse 5pm-9pm. I have plugged my bathroom/sink with plugs and its 100% coming from the toilet. Tried Lugi worlds best plunger, that air gun blaster and 50 buckets of hot water down the toilet for 2-3 days and no joy, the...
Hi all, I would really appreciate your eyes on these pictures - What do you see ? Does anything look strange about the Rockwool insulation to you? I suspect that my long ongoing rotting veg/sewage smell is caused by a fault in this connection that has been hidden from previous inspections...
My living room smells like a sewer but I can't tell where it is coming from. Not sure where to start looking. The saniflo discharge pipe runs above but there is no sign of leakage on the ceiling. The main drain run from the manhole at the back runs under the kitchen, which has a solid floor...
First of all, apologies, it seems this topic has been posted but don't believe my specific issue is covered. So been living in my Victorian house for almost 10 years, no issues. Have 2 bathrooms, 2 loos that all go to a large underground soakaway, I believe. I can only see one soil vent pipe...
