Discuss Help request - shower hot water cutting out in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi there
Looking for some help please.
We have a Triton T300si. We had a leak in the remote unit. Plumber said it was a problem with the stabiliser so we bought a new one and plumber replaced it.
There is a new problem now. When the shower is switched on, after a few seconds the hot water pressure drops/cuts out totally, something in the remote box sparks, and it switches itself from the 'high' setting on the main shower unit to 'cold'.
It then won't let you change it up to high again (not that the water was ever hot anyway). All this happens within a few seconds of putting it on, and the water pressure drop/spark at same time.
Plumber insisted 'I've fixed the leak' (which is true) but can't offer any real solutions to lack of hot water.
For what it's worth, he says he thinks it is tripping out because some electrical parts in the shower have been damaged by water. He doesn't know what bit and we can't tell by looking.
Fyi when it was just leaking (pre new stabiliser) it wasn't tripping out or hot water pressure dropping/cutting out - the shower worked hot, it was just leaking.
Please help!
Ps. Has plumber caused this new problem?
Don't triton offer an 80 quid fix fee ??
From my experience electric showers are never worth the hassle of running around for parts.I'm surprised you got someone out to repair the first issue.
Contact triton ask for fixed rate fee for repair if I was you .
Reply to Help request - shower hot water cutting out in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air gap as I was having dripping from the pressure relief valve. Since then I've lost a lot of pressure from the hot water feed to my shower. The rest of...
Hoping someone can please help. I have an intermittent fault with my electric hot water. I have an older style electric hot water service that heats on controlled load over night. The large tank is in roof space of 60s built villa unit. Every few mornings, no hot water will come out of...
The Water Board have just replaced the main water supply to our property. We have a ground floor combi boiler. The central heating system for the whole house is working as normal. Hot water is working as normal on the ground floor. However, there is no hot water to the first floor bathroom. This...
Hello, We hade a problem with our hot water not working in one of our bathroom's (all other outlets were working) Therefore we got the Thermostatic Shower Valve changed and everything was working again. However a few days later, both hot and cold no longer works for the bath and the hot...
We have recently had water hammer issues. Plumbers have installed an arrestor near our kitchen sink and a device in the toilet cistern to slow water shut off. Worked for a bit, but hammer returned. This morning, while the toilet was refilling and the shower was on, there was a loud thud that...
