Discuss Help needed with this part in the Plumbing Forum area at UKPlumbersForums.co.uk.
  1. Build advice
    Build advice New Member
    I've recently purchased a grohe rimless toilet and found this component. What is it and do I need it? I was expecting everything that I would need in the cistern to be already in place?? Please can you help? Thanks
  2. ShaunCorbs
    Right hand piece is an inlet strainer saves any rubbish going up the ball valve
    I’m guessing left is a flow restrictor for the inlet
    • Agree Agree x 1
  3. Harvest Fields
    Looks about right Shaun
  4. Build advice
    Thanks for that. There was some paperwork that came with it but I still can't understand if I need it and if I do how do I go about fitting it? I paid s fair amount for the toilet and was hoping it would be a simple install.
  5. Harvest Fields
    They go into the bottom of the inlet valve.
  6. Build advice
    Anyone got a video showing how to do this? Many thanks
  7. ShaunCorbs
    tbh i never fit them
    but to fit them follow the instructions 1st pic
    tbh if you cant follow them good luck installing the toilet and setting it up
  8. snowhead
    snowhead Plumber
    If the water supply to the WC is mains, you'll most likely need the restrictor as well as the filter.
    If it's tank fed, no restrictor, (unless you live in a ground floor flat of a tower block)
    • Like Like x 1
  9. rpm
    rpm Trusted Plumber Top Contributor!!
    Install the fill valve in the cistern first then slip them up the stem just as you connect the pipe underneath.
  10. Build advice
    The toilet is fitted and plumbed to the inlet (builder did this)only i discovered this part at a later stage. The builder did not even bother mentioning it and now he's away on another job. I open the cistern and look inside and think wth. I thank you for all your advice but I still don't know 1. If I need it and 2. How to remove the innards of the cistern( which all seem securely attached) and fit it?? Sorry guys but I need a bit (lot) more help!
  11. Allgoode
    Allgoode GSR
    Well you're builder installed it & as we all know builders know everything so just get him back & he can explain if you need it & the reason's why.
    As mentioned above by Snowhead the reason's they are fitted or not are correct supply dependant.
    Cheers,
    Andy
  12. Harvest Fields
    How long has the toilet been fitted?
  13. Build advice
    Been fitted about three weeks ago but water has not been switched on. Thanks
  14. king of pipes
    A simple 2 minute job you may or may not need it depending on your water pressure possibly a good idea to fit the filter though it slides into the inlet of the valve. Tkop
  15. Build advice
    Thank you for that. Should I remove the mains water connector and push the filter and restrictor up into the inlet and then reconnct? Or do I need to remove the inlet from inside the cistern?? Thanks
Loading...
Similar Threads - Help needed part Forum Date
Advice Needed Help! Old Style Gas Hob Gas Safe Register Forum - Public Forum May 18, 2019
REGULAR BOILER HELP (HEADER TANK IN LOFT) Plumbing Forum Yesterday at 11:16 AM
