Discuss Help identifying tap valve in the Valves & Taps area at UKPlumbersForums.co.uk.
  1. Simon42
    Simon42 New Member
    I have a dripping valve on my towel rail, but when I removed the cartridge it doesn't seem to be the standard one, and I don't know how to find a replacement.
    I'll attach a photo. Any help welcome.
  2. Harvest Fields
    This may be a wind up. But if not then can we have a picture of the valve on the towel rail.
  3. ShaunCorbs
    need to replace the whole valves not the same as tap cartridges
  4. Harvest Fields
    Did you see where is was going with this?:D
  5. ShaunCorbs
    yep
    • Funny Funny x 1
  6. Simon42
    Simon42 New Member
    Are you saying that even though it's dripping from the end of the brass bit, where the moving spindle meets the fixed part of the brass body, that you can't just replace this bit, and have to change the whole valve, body and all?
    I actually swapped it in the live system, for one of a different design but that had the same thread, which works but probably only because I never actually turn that radiator off.
    If I had to replace the whole valve, I'd have to drain all the upstairs system that I couldn't otherwise isolate :-(
  7. Riley
    What’s the system?
  8. Harvest Fields
    Now I am confident this is a wind up.
    • Agree Agree x 1
  9. Simon42
    Simon42 New Member
    This is a serious question, that I thought you folks would be able to answer in a second with "oh that's a valve type X, go here pay a tenna, do your slightly mad live system swap back and job done".
    This would surely be the world's most boring wind up ever.
    I am clearly missing something.
    I'll add some pictures.
  10. Simon42
    Simon42 New Member
    This is what it looked like originally.
  11. Simon42
    Simon42 New Member
    And this is what the one I replaced looks like now (which is also dripping).
  12. Ben-gee
    Ben-gee Plumber
    Please take a photo end on of the valve you removed in photo 1
  13. Simon42
    Simon42 New Member
    Hope one of these is what you are after.
  14. ShaunCorbs
    Correct need to replace the whole straight rad valve
    Also are you using them often eg turning it on and off ?
  15. Ben-gee
    Ben-gee Plumber
    If it's leaking up the spindle you could strip it down (as you have but also remove the horseshoe clip and push out the spindle)
    Replace/grease up with silicone grease any o-rings you find and re-assemble the valve. The problem you will have, as always, is getting the correct size o-rings - but if you do it will be as good as new.
Loading...
Similar Threads - Help identifying valve Forum Date
Help identifying a toilet cistern filler valve? Plumbing Forum Jun 2, 2019
help identifying this bath/shower mixer Valves & Taps Jun 26, 2019
