Discuss Help identify again please in the Valves & Taps area at UKPlumbersForums.co.uk.
Tags:
  1. Andy Raven
    Andy Raven New Member
    Hi
    Could anybody help identify the box next to the temp gauge please, inquisitive!
    ta
  2. YorkshireDave
    YorkshireDave Plumber Top Contributor!!
    Id say a temp sensor.
  3. rpm
    rpm Trusted Plumber Top Contributor!!
    Is there nothing on the label you could google?
  4. Last Plumber
    Last Plumber Trusted Plumber GSR
    Is this a commercial building like a residential home?
  5. rpm
    See the OP`s other posts before getting involved. ;)
    • Like Like x 2
  6. Last Plumber
  7. rpm
    I saw before the edit, now follow that fitting back and down, spot anything wrong?
  8. snowhead
    snowhead Plumber
    Temperature sensor connected to a B.M.S system like Trend.
    The one in the picture is made by Titan
    • Like Like x 1
  9. Last Plumber
    AH!..took a minute to work that out!
    I was talking about the corrosion on the elbow (that's what it looks like on that photo to me anyway) .
    It made me think of the reactivity series, de-zincification and how we never used to use brass fittings on hot water systems as a rule. I was asking a question of @YorkshireDave@YorkshireDave as he was on here at the time but that was yesterday and alas, the question has slipped my mind. It will hopefully return soon. If it does, I will be back with it.
    • Like Like x 1
Loading...
Similar Threads - Help identify again Forum Date
help identifying this bath/shower mixer Valves & Taps Jun 26, 2019
Help identifying tap valve Valves & Taps Jun 8, 2019
