Discuss heater exchange baxi duo tec ???? in the Plumbing Forum area at UKPlumbersForums.co.uk.
  1. tarb
    tarb New Member
    before i buy a new boiler can anyone give me peace of mind please
    got a 10 year old baxi dou tec that's losing pressure within a few hours/. replaced expansion tank and prv which helped for a week but now just as bad
    condensing pipe running all of the time and radiators constantly got air in them but cant find any visible leaks
    been told heater exchange but been told the wrong diagnosis before
    any help would be appreciated
  2. king of pipes
    king of pipes Trusted Plumber GSR Top Contributor!!
    Get it replaced it sounds likely a 10 year old boiler is not worth spending money on, the baxi platinum 33erp is a straight swap and will give you 10 year manufactures warranty . Kop
  3. Andyh
    Andyh GSR
    Try isolating boiler from system via valve s
    For 24 hours if pressure drops definitely boiler, however I've tried this before never had a positive result though . Put leak sealer in rad and then check condensate trap for the leak sealer , which shows leaking heat exchanger. And Baxi replace heat exchanger as part of one off repair, around 290 I think
  4. Last Plumber
    Last Plumber Plumber GSR
    I'm with KOP on this one.
  5. tarb
    tarb New Member
    Thanks I’ll admit defeat and get a new boiler but just my luck I do and it was an easy fix lol
  6. tarb
    tarb New Member
    Losing pressure within a couple of hours and still thinking should I buy some leak repair fluid from Screwfix
    • Like Like x 1
Loading...
Similar Threads - heater exchange baxi Forum Date
Oso unvented water heater, leaking and brown marks? Plumbing Forum Yesterday at 10:16 PM
oil heater air fuel ratio question Central Heating Forum Monday at 6:20 PM
