- Messages
- 5,167
Stop a slight weep on a solvent weld fitting? I would just cut this out but it is on a short soil pipe boss connector and if cutting it out and replacing means changing a lot.
Cheers
Cheers
Discuss Has anyone been able to... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Denso tape , proper bodge job but works
They should do though.Pardon me, but why use that sort of stuff when you can do it properly?
To use it in this instance only means you put off the inevitable - doing it properly. Unfortunately though the customer is never going to ask anyone back who's job has failed a little while down the road...
Gap filling solvent weld
Can’t remeber it’s name
Or make your own!
Reply to Has anyone been able to... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
