Discuss Grundfos UPS3 - Central Heating Pump in the Central Heating Forum area at PlumbersForums.net
When a pump is switched off does circulating water stop immediately? In other words, is there a bypass within in the pump to allow the water to slow down to a stop?
Thanks for any advice
It stops pumping but the water doesn’t stop right away but eventually will stop
Hence sometimes you will get the pump pcb lighting up without power
Water can flow straight through a centrifugal pump when it's not running, with only a small headloss. So flow will continue for a short while after the pump stops.
Reply to Grundfos UPS3 - Central Heating Pump in the Central Heating Forum area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
