Discuss Grohe Sink Trap doesn’t fit pipe in the Plumbing Forum area at UKPlumbersForums.co.uk.
  1. Profic
    Profic New Member
    Hi All,
    We recently purchased a Grohe sink and sink trap. However the Grohe pipe is smaller than the standard fitting. Have tried local plumbers merchants and supplier to get an adaptor but no one seems to be able to supply one.
    looking for a 32mm - 34mm adaptor.
    Any suggestions?
  2. Craig Watson
    Craig Watson Plumber GSR Top Contributor!!
    You need a 1 1/4" compression fitting
    • Agree Agree x 1
  3. snowhead
    snowhead Well-Known Member
  4. Profic
    Profic New Member
    The Grohe bit is 32mm but the wall fitting is 34mm. Ideally looking for a 32mm - 34mm adaptor? Or plastic ends with the different sizes?
  5. ShaunCorbs
    11/4 compression elbow
    • Agree Agree x 2
  6. rpm
    rpm Trusted Plumber Top Contributor!!
    Certainly wouldn`t reuse what`s in the photo regardless of whether it fitted or not!
    • Like Like x 3
    • Agree Agree x 2
  7. Riley
    Def 1.25” compression
  8. oz-plumber
    oz-plumber Plumber
    That fitting under the plastic elbow in the picture, is the fitting I think you use to connect the horizontal pipe from the trap, to the pipe coming out of the wall.
    You will either need a pipe socket to 40mm or 32mm thread. (depending on the thread size of the fitting )
    That's how we do them.
    Some people just push the trap pipe inside the PVC pipe and silicon it.
    I wouldn't recommend this method
  9. Riley
    Isn’t that fitting just a shroud for where it passes through the wall
  10. oz-plumber
    oz-plumber Plumber
    More explanation:
    The fitting in the bubble wrap is the shroud ( left side of pic )
    Fitting under ( right side of plastic elbow) is the fitting that seals the chrome pipe to a threaded fitting coming out of the wall
  11. Craig Watson
    So that fitting next to the elbow threads onto a typical 1 1/4" compression fitting and acts as a push fit adaptor?
  12. Riley
    Sorry oz yes, If I open my eyes I will see
Loading...
Similar Threads - Grohe Sink Trap Forum Date
Grohe amera shower. Bathrooms, Showers and Wetrooms Yesterday at 9:09 AM
Fitting a hansgrohe ShowerTablet Select 300 Bathrooms, Showers and Wetrooms Feb 1, 2019
