Discuss glow worm fuelsaver manual needed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Steve weightman
really would be appreciated if any one has the glow worm fuelsaver 40br installation manual to hand having to do many visits to get it sorted out.
Or if anyone has had experience with spillage on these .the boiler case seal is new, heat exchanger cleaned sight glass new,external flue edges sealed but still setting off co detector
I can't find the manual online anywhere, a spares website lists the manual as obsolete but still sells the gas valve for it :confused:. I don't know whether the boiler is open flued or not so it may not be relevant but have you checked the room has sufficient ventilation? And if it worked fine before the gas valve died, are you sure you've installed the correct gas valve or is burner pressure etc all ok?
Gas valve and burner pressure all ok . It's the balanced flue sealed boiler. Got the manual emailed from glow worm and been back today. I discovered another boiler seal at the back of the boiler almost like dust so badly brittle so been back this morning and smoke bombed from outside. As you can see I found the issue
Reply to glow worm fuelsaver manual needed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
