Discuss Getting Water hammerage at boiler. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Azz
went to see a job and boiler is getting water hammerage when taps are closing fast. I thought this would be just hot water pipe as the taps in the house are quarter turns. The problem is, it is also causing hammage to boiler when using cold water pipes as well and when using the cistern flush.
I take it I need to install shock arestors but where would it be recommended?
the boiler is main combi 24he and I think, this problem is causing diverter valve damage as the customer changed valve a year ago and its already has leaking marks and domestic water heat is leting by to the heating side.
Any sugestions?
I did try holding cold water and hot water pips firmly under boiler while having taps turned on and off to eliminate loose pipes but it is still hammering. Would this be correct to eliminate loose pipe diagnostic. The sound is mainly coming from boiler.
If it’s at all outlets and we, then as above could be dead legs in system with trapped air. It can also be stopcock jumper or a failing quarter turn tap. It all depends on how much water hammer - is it vibrating the pipes whilst water is being used?
Hi, I am gsr and have previously asked to join the forum as would like to asked in depth questions which I am unable to get response on the open forum.
If this is a boiler problem then why would it hammer when cold water taps are open to?
Maybe it's not boiler related, but have you checked anything that we have suggested?
Reply to Getting Water hammerage at boiler. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My first thought when I heard this fault a combi boiler with hot water but no heating. Was a problem with the stat, controls not making the call for heat. If this is not the case. Can the divertor valve be the cause of the issue?
When I put the central heating on the hot water gets drawn through the pump but is then being diverted straight back to the boiler instead of the rads What is this, and how likely is it that it is faulty? That sits in between the hot water to the rads and hot water to the hot water tank...
I am having a problem with my main 24he boiler where the flame is constantly clicking on and off with the heating and when using hot water. Some times the flame failure light comes on but it ignites again after a few seconds. The plumber has changed a couple of sensors on the boiler and checked...
I have just moved into a late 1990s new-build house with a small bore (about 1/2" OD pipes) gas fired boiler central heating system. All the normal radiators get hot but two of the three towel heater/radiators don't get hot and the pipes feeding them are cool to the touch even after the boiler...
Hi, I have a Vailant EcoTec Boiler with a Megaflo. These are controlled by a Honeywell controller. I have one 3 port diverter, where one of the outputs goes to a 2 port diverter prior to the Megaflo (I believe this is some safety feature). I have run into an intermittent problem where some...
