Discuss Gas volume calculation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I-kal
hey Guys I wonder if someone could help me out.
I wanted to find out if I could work on this domestic installation. It’s a house with 2 boilers 24 kw each so 48 in total, the gas meter is a g10 which I believe can be used as domestic and commercial. The gas pipe is run in majority 28 mm at 12 meters and 2 metres in 22mm. What would be the volume of gas in as I am aware as a domestic engineer I can work on 70kw and less with upto 35mm pipe and a gas volume of 0.035m3 and less. Appreciate the help thanks
First things first are you gas safe?? I’m assuming yes. Daft as it is because it’s pretty specific but we do not discuss has topics in open forum. Send a copy of the front and back of your card to @Riley @Harvest Fields or @ShaunCorbs and get your posts up to ten or more and we’ll get you access to the gas safe only section.
This is the thing it’s over by quiet a bit so I must be doing soemthing wrong. I have been going over books etc to see if my working are correct so I thought someone on here could guide me.
fill this out
28 mm at 12 meters _________ x 12 =
2 metres in 22mm __________x 2 =
total = ______
+ 10%
total iv _______
g10 meter _____
Ivt _____
its close
Are you adding pipework to the system, in which case it may be under to start but over after the addition?
Or just working on the boilers?
so have i
28 mm at 12 meters 0.00054 x 12 = 0.00648
2 metres in 22mm 0.00032 x 2 = 0.00064
total = 0.00712
+ 10%
total iv 0.007832
g10 meter 0.025
Ivt 0.032832
Reply to Gas volume calculation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
