Tony Clifton
- Messages
- 20
The Polish round here have been claiming free gas on the old U gas meters by disconnecting and putting a vacuum on it to rewind the dial, can this really be done?
Discuss Gas meter in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Seen them do it
yes I agree its like a free for all on knowledge. If the gas company suspect you of stealing gas ,They will remove the gas meter and send it away to an independent lab and they have a way of proving the meter has been clocked , So be warned you will get done
Without giving too much away ,there are ways of determining whether or not a meter has been fiddled. Even so,gas suppliers software is pretty accurate when it comes to estimating bills so if they see a sudden drop in consumption..well..there is usually only a small number of reasons why.
luck for me ive tapped my gas off next door when they were on holiday so its all free!
hose and jubilee clips. Or speed fit 10mm ??
now if you used 40-50% less than last year it might look alot more suspicious.
so what your saying, split a 15mm before the meter then rejoin the outlet 50/50 so to speek.lol.
whats the c.v and can u bottle it.lolThe only free gas I get comes from my backside, and believe me:
NO ONE WANTS IT. Free or not.
If the meter is outside..your gas will be cheaper in winter...if meter was turned on side gas flow rate be same and dial would slow down or is this just crap that polish plumber told me today
by what percentage, do you know?If the meter is outside..your gas will be cheaper in winter...
Reply to Gas meter in the Plumbing Jobs | The Job-board area at PlumbersForums.net
