Discuss Gas cooker connection unusual in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all.
I've bought this candy gas oven second hand but unused. The problem is It won't connect with the usual gas hose to the mains. I have shown this to a relative who's a heating engineer and he hasn't seen this before. I also contacted candy and they were worse than useless. On first glance it looks like it needs barrel. But it doesn't. It has a flared end and the threaded part slides along the pipe. It will need a fibre washer and a female connection. Does anyone know what that connector would be please. (Candy ovg505/2x gas oven. )
Reply to Gas cooker connection unusual in the Plumbing Jobs | The Job-board area at PlumbersForums.net
N
Hi all, did a quick google search and came across here! I hope you can help me out with what seems like a very simple solution, I just don't have the proper knowledge of it. I'm just trying to connect a gas line to a dryer, looked up the simple video go-to guides. However, each time I install I...
Hi, Please can someone advise me on the correct replacement parts to re-connect my gas hob? It is an Indesit PIM 640 AS fitted gas hob and the manual states the fitting is a threaded 1/2 gas cyclindrical male attachment. Do I also need to order a fibre washer or o-ring for this? If so which size...
1K
Hello, I am hoping you can help me. I need to connect an outdoor NG grill to an existing outside NG supply connection. I need to get the right hose to attach to my grill. A few background facts: -My Grill requires 124000 BTUH Total gas consumption with all burners set to HI -My Grill...
1K
I know very little about plumbing, so I'm not even sure what to ask for and I may use the wrong descriptions of items, so apologies if so. I've done some searching online, but not entirely sure what I need to get. I recently moved into a house that has a gas outlet on the deck. I bought a...
1K
Hi all, relatively new to the gas industry about a year and normally just do fires and boilers. The only reason i have the cookers ticket is for lgsc's. I am fitting my first freestanding cooker tomorrow and i have a few questions which may sound dumb. 1. Is changing all the injectors...
