Discuss Floorboard holesaws................ in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Scott_D
Subscribed
Are these any good for chipboard flooring?
Does the 'plug' fit flat so that you wont see it under carpets?
Seen many a new build floor riddled with them, plasterers shove up the boards and trap the wires between the underside of joists :D
Poor old sparks, has to free em
The hole and rebate is made with a special hole cutter that matches the plugs. There’s a smidge of a gap around the perimeter of the plug... but even linoleum would cover and not show through.
Normally fit the extra / plastic discs
Wouldn’t recommend for traffic areas unless you glue it down
Yep
https://www.NoLinkingToThis/p/erbau...MIuvOFuYDr4gIV5p3tCh0FfgmuEAQYASABEgKuCfD_BwE
https://www.NoLinkingToThis/p/erbauer-armeg-sbc-cover/10648
It’s for a loft conversion
I need to get pipes under the floor before walls are built.
It will have to be push fit
I can then make a hole and reach in to connect the rad pipes
You can put the plug back into the hole but of course firstly you need something in place to support it from underneath. Pass a short bar of wood through the hole and screw it on straddled across the hole from underneath so that the bottom of the plug has something to attach to. I usually just glue the plug onto the bar but not onto the surrounding boarding. Therefore you can always unscrew the bar with plug attached in case you need to access the hole again in the future.
Reply to Floorboard holesaws................ in the Plumbing Jobs | The Job-board area at PlumbersForums.net
